Tenon saw handle
fred
Jersey
I've picked up a Henry Disston 14" tenon saw off ebay, for £5.50 +p&p. The blade is sharp and true but the handle is too small for my hands (can't get all 4 fingers through). It also needs a recessed nut and bolt. The original one has been lost and replaced with a machine screw and nut.
Where's best to get a recessed nut and screw (Is that the correct name?) that will match the existing the existing other two?
And is there enough wood on that handle to cut away some of the lower part to create a "open" handle, or should I make a new larger handle that will fit my hand? Just wondering if the handle is too precious to be altered and should be kept as is, possibly sold on? I don't want to butcher an antique!
Cheers :obscene-drinkingcheers:
fred
Looks a nice saw, have you tried holding it with you index finger along side the handle, pointing at the cut? That is something I do if the handle is on the small size.
You need what are called TEE nuts for the handle, not to be confused with the ones sold by screwfix, check out the workshop heaven web site, Mathew should have them in stock.
It's usual not to put four fingers through the handle - the index finger points down the side of the back/blade, it helps keep the saw and the forearm in line.
Thanks Dave, i'll have a look now.
And i'll give the finger-down-the-side technique a go.
Bob, I was thinking just the same. Unfortunately I haven't got the funds, and wont have a for a while. I'm currently off work with a prolapsed disc (have been for a 2 months), and waiting for the consultant surgeon to get in touch with a decision on whether it's going to be epidural injection or surgery. Had an MRI scan last week, which was amazing, it was like being in a sci-fi film, very much like 2001: A Space Odyssey, and the sounds made by the machine reminded me of Faust, Pink Ployd and German industrial techno music.
Cheers chaps :obscene-drinkingcheers:
fred
Dave,
I've been in touch with Matthew, and a new brass saw nut has been ordered.
Many thanks for the help mate.
cheers :obscene-drinkingcheers:
fred
The handle (and saw ) are not that old as relatively speaking it's tending on the plain side.
Making saw handles is not that difficult so I would have a go at a new one in a vintage style - there's lots of outline drawings on the internet.
The open handle style is generally used on smaller (dovetail ) saws - a closed style is more suitable for yours?
