I reckon if you use the tables for floor joists, they will be more than enough for your green roof.tabs":2c7v5bvz said:Thanks Malcolm, will take a look. I've found a site that gives joist sizes for flat roofs which is near enough what I will be doing.It says 50x150mm at 600mm centres will do a span of upto 2.97m so will do my 2.4 span easily. Just need to find out now whether this would support a green roof of 60-100kg per sq m.
9fingers":3a328kib said:I reckon if you use the tables for floor joists, they will be more than enough for your green roof.tabs":3a328kib said:Thanks Malcolm, will take a look. I've found a site that gives joist sizes for flat roofs which is near enough what I will be doing.It says 50x150mm at 600mm centres will do a span of upto 2.97m so will do my 2.4 span easily. Just need to find out now whether this would support a green roof of 60-100kg per sq m.
I would never use a green roof personally but everyone to their own![]()
Malc2098":2pmxy0rn said:Sorted, it seems!
From the net --- C24 graded Premium structural timber is a stronger, more demanding grade and has fewer/smaller knots than C16. C24 is best used where higher loads or wider spans are required. C24 will carry a higher point load than C16 grade.
tabs":397sb4gh said:Malc2098":397sb4gh said:Sorted, it seems!
Cheers will see if I can get some tanalised C24.
tabs":34noqz3l said:Oh , also looking for recommendations for suppliers . The one I've been looking at to get rough idea of cost says they use pallet couriers so is going to be no good as I assume that means I would need a truck to unload
tabs":1r00knwi said:Oh , also looking for recommendations for suppliers . The one I've been looking at to get rough idea of cost says they use pallet couriers so is going to be no good as I assume that means I would need a truck to unload
Coolhands":2k83jzb6 said:I... I'm now thinking I might use GRP system like 'Cure-it'.
Mike G":3cbb8kgw said:Good stuff Tez. It soon takes shape once you're framing.
What are those bricks in the foreground, just in front of your new plinth?
In the picture below you can see the first stages in the construction of my warm roof. I didn't get any pictures of the osb decking(18mm) but you van see the vapour membrane on. I later had to remove this as it ripped in strong winds. I replaced it with a strong vapour proof layer using some DPM9fingers":xrlaux83 said:Brilliant progress all inside 30 mins too :lol: :lol:
