Three letter searches
AndyT
Bristol
The current forum search facility ignores words of three letters or less. This is a bit of a disadvantage if you want to search for words such as oak, ash elm or yew.
Is the restriction still needed, or could it be relaxed please?
My guess (based on zero data) is that it's a forum limitation rather than a setting. I've generally found the forum search pretty awful anyway so I just use a web search engine & append "site:thewoodhaven2.co.uk"
e.g. https://duckduckgo.com/?q=oak+ash+elm+site:thewoodhaven2.co.uk
Actually, I take back what I said: I just checked the (XenForo-based) MIG welding forum & that allows you to search for 3-letter terms (which is handy for things like MIG, TIG, Gas, Arc, MMA etc!)
It is and isn't a forum based limitation.
XenForo has a simple setting which is indeed set to 4 characters as the shortest string for searches, but moving it to 3 characters makes no difference because additionally there is an underlying 4 character minimum setting in the MySQL database.
As the server is a virtualised shared server - this is a setting that can't be altered (as it affects all MySQL instances running on the server which is 100s - 1,000s of databases), it is a compromise of cheaper hosting...
there isn't a way therefore to directly update this - two slight fudges are either to take Dr Al's approach, and use a search engine - or you can search on e.g. oak* which won't strictly find the three character instances, but may find some relevant threads...
Ah, thanks, that makes sense.
😳😳 If you are a member of the Digerati(?) Andy!
I just about got: "piece of code specifying four letters is inaccessible".
I hasten to add I did have a basic (Ha! See what I did there?) grasp of Fortran and C in the mid-to-late seventies, but things ran away from me with "shadow memory" etc in the eighties.
