StevieB
I have spent the last 3 months, on and off, doing some work for a friend of SWMBO's. The latest job was to install 2 6ft x 6ft metal gates to form a new driveway entrance. These were old and the standard curly scrollwork stuff that was standard fare at one time so fairly flimsy. Said friend has limited cash so I was really just helping out as and when, this is not a paying job. She is happy with the gates, but wanted to know if they could be clad in timber so that people could not see through them. They have a metal strip top and bottom I could screw through so this is feasible, but I am concerned by the weight - the gates themselves are only 15mm thick and held on 2 hinges each with eye bolts over a standard hinge pin. That pin is 13mm - I cannot go wider (to a standard 19mm pin) as the gate is too narrow for a wider eye bolt and I am not about to start messing with welding on extra supports etc. So my question is - how would you clad these gates, keeping weight (and cost) to a minimum? Couple of options:
Plywood sheet - looks naff, will delaminate and quite heavy but relatively cheap
Composite plastic decking - expensive, may look naff, rarely reversible and may be ribbed
Hardwood decking strips - current front runner, but need smooth planed both sides ideally and also weighty and relatively expensive but will give the best overall look I think
wood effect plastic wall panels - light but likely to look like what it is, so very naff and possibly white on the reverse!
Or something else? Any suggestions welcome, I am out of ideas here and desperately trying to avoid being cornered into doing an entire new driveway behind the gates as well.....
