Torque screwdrivers!
wallace":1c5bko61 said:
I really should have my consumer unit changed, its still got fuse wire in the breakers :shock:
I'm hoping it looks something like this... ;)
That would be cool Andy, I did pick up some new old stock volt meters that had a plan to use on my 3 phase
Doing the sort of work you do Wallace, I'd stick with wired fuses as you have a bit more tolerance than MCBs which will pop at the slightest hint of a bit of an overload.
A serious problem and a wired fuse will still blow and protect the wiring.
If it is of any comfort, my workshop where I do my electrical tinkering, is all wylex wired fuses.
And at the other end ... :D
9fingers":kzu5s89a said:
Pete Maddex":kzu5s89a said:
My HiFi amps burnt out the 16 amp mains switches their was virtually nothing left of the contacts, caused by having 500VA transformers and 60.000uF caps.
I replaced them and now leave them on all the time.
That is one solution but you could always add a current limiting resistor in the charging path which is shorted out with a relay when the capacitor voltage gets to say 90% of the target value.
This approach is used in nearly every motor inverter as they would have a similar power on surge issue. It works very well and it is also more gentle on the capacitors.
I am building their replacements with a soft start module in and some other mods that should make then sound very good.
