Yep, A place for everything and everything in its place. If only I could remember where that place is.
Andyp":3ff13ywa said:Yep, A place for everything and everything in its place. If only I could remember where that place is.![]()
It's the way to do it, but my problem now is that I'm starting to run out of space to put 'stuff'TrimTheKing":19f8az1l said:Andyp":19f8az1l said:Yep, A place for everything and everything in its place. If only I could remember where that place is.![]()
That’s my big problem and one I want to try and rectify as I stock the shop.
Going to have all ‘things’ of a certain type together and label that particular container/space. Not really worked out how as yet so it’ll be organic initially.
Andyp":3qrhhht3 said:Ever considered these Mark.
Make them up on the mitre saw in pairs from scrap wood
Andyp":px63mgw1 said:Ever considered these Mark.
RogerS":7huozw16 said:Andyp":7huozw16 said:Ever considered these Mark.
How on earth do you make those without leaving a circular cut ? :eusa-think:
9fingers":ka3dofp9 said:RogerS":ka3dofp9 said:Andyp":ka3dofp9 said:Ever considered these Mark.
As Andy says " using a mitre saw"
Could even do them at 45 degrees on a table saw.
RogerS":55z4pycd said:9fingers":55z4pycd said:Those tins are great for storage. I have lots from when my son was a baby. He is nearly 32 now!
:eusa-doh: I knew there had to be a reason for having kids :lol:
Blackswanwood":btbxeffz said:Looks good ... I am guessing from the footwear that Mrs Trim just popped in to pose for a photo!![]()
Cabinetman":2q3qcq0x said:That’s going to be a lovely light space to work in, it’s tedious sometimes isn’t it having to do one thing to be able to get another thing done to finally get to where you want to be but that’s what it takes. Just slightly concerned about your planes crashing to the floor, Ian
Yes I’m helping my son Ben soon with his overflow shed, he has acquired a big pile of 8x2”s which we are halving for the wall frames.Well that's a nice pragmatic solution.
My solution to an overcrowded workshop was to build another shed, and put everything which isn't woodwork-related out there.
No, but as you can see from pic 2, I played around with the pivot point until they hung just shy of vertical for just that reason.Do those boxes have a stop to prevent them from swinging down just before the perpendicular? Would that help prevent stuff from falling out?
And you do know that stuff expands to fill the space made available for it![]()
Yep exactly what I plan to do in positions where boxes will meet. The light panels conflict this slightly so I might need to play around with those a little to make that work, but that's not a biggie....the offcut used to support the boxes, if it were just slightly longer and you had one on every joist you could support both sides of each box...
Me too, so I'll be putting something on them as an aide memoire as to what's inside.Like it! if this was done in my shop I would need a label on it.
What I did in my previous place though it was a long time ago was use some of those see though A4 plastic sleeves ('cos they were free from workMe too, so I'll be putting something on them as an aide memoire as to what's inside.
Labels are a big time saver in finding stuff and making sure things are put back where they belong.What I did in my previous place though it was a long time ago was use some of those see though A4 plastic sleeves ('cos they were free from work) Stuck them to the door fronts with D/S tape and then printed off a quantity of sheets with empty boxed sections. I listed the contents using a sharpie then whenever I rearranged things, which was often I just slid in a new sheet.
I haven't done that here and know where everything is until I have a tidy up session then I'm stuffed.![]()
