Trivets 2015/23 & 2025 + 1 more Kiaat
Southern Africa 0054
This is the 2015 thread, re-posted in 2023 with pics.
The 2015 thread pics were lost in k-ktbucket.
https://www.thewoodhaven2.co.uk/threads/trivets.8438
The design inspiration was from an article “Waffle Pattern Trivets”, pattern number 3.
https://www.craftsmanspace.com/free-projects/waffle-pattern-trivet-plans.html
Right, now the 2025 version ………………….
I was donated some Red Oak offcuts by my beehive friend and had all the American Ash offcuts from his steps project.
Timber cost = Zero.
They had already been through the planer on the EB-TP.
The Oak had a 10mm strip cut off the length which would be used for feet and the one Ash had strips cut off the long edge, 10mm, for feet.
Why feet? This is a different design to the previous ones and I was being overly cautious of heat transfer to a table surface.
The Oak would get 9 holes of 30mm drilled using a Forstner bit.
The Ash would get rounded grooves for the top.
Ash size 205mm long X 125mm wide X 23mm thick. The Ash is a bit narrow but can be used side by side in the width and length.
Oak size 200mm X 200mm. Nice size for a trivet.
See the Finishing Thread
https://www.thewoodhaven2.co.uk/threads/fuming-test.10695
The Oak and feet and one piece of Ash went into the ammonia fuming box for a couple of days. The other piece of Ash and the feet were left au natural.
The Oak was marked and drilled using the drill press.
Forstner Drilling Station
  • 30mm for about 1.5mm
  • 20mm for 10mm
  • 10mm right through.
  • 30mm right through.
The slowest speed was used.
The Oak is a bit brittle on the exit side, not serious, a bit of sanding will deal with it.
Oak holes, not too shabby.
Next is the visit to the router table.
The Oak and Ash top edges received a smallish round over, made it look very good.
Oak top
Should have also done the Ash ends &&%$%#!
Oak feet
Oak-Edge-Feet.jpg{
Oak feet edge
The Ash was measured and marked to get 5 grooves, 8mm deep. The small round bit was used.
A tedious process, raise bit 0.5mm, rout both boards outside grooves, both sides of the top. Raise bit 0.5mm and repeat until groove about 8mm deep.
Move the fence for the next rows, repeat above process.
Finally move the fence for the middle grove, repeat above process.
The Ash is really nice to work with and has some beautiful grain pattern. New sharp router bits.
Ash Grooved
The feet were drilled, countersunk, and screwed on using 20mm screws. The Ash required pilot holes.
Ash plain & fumed feet
Some hand sanding before sealer being applied.
I used Woodoc 5 Interior. The end grain sucks it in, so be patient and keep on applying. Let dry overnight, some light sanding with 340grit.
After final coat sanding using 1500grit, takes the shine off and any dust nibs.
Sealing station
Ash fumed sealed
Ash plain sealed
The Ash had a slight unevenness on the width, this was one of the warped boards, so it required some small brown felt squares to be glued on.
Thank you for reading
Great work Phil, the ones I like the best are the Ash fumed grooved trivets. When fuming do you place the container outside in case of leaks at the lid? Asking as I have never done the technique.
Thanks Scott.
I have a largish hard plastic 'toolbox' which seals quit well and have not detected any leaks.
Son and DIL purchased old (45yr) house.
Previous owners (who built) built in some lose Kiaat cupboards and pelmets in the lounge.
The pelmets were all taken down and my first question “what will you do with them?” O, they will be stored in the garage.
Move on about 8 years …………
He cleaned, sanded and sealed sections that were installed as bookshelves.
Very generously I was given an offcut 300mm x 180mm x 20mm.
The 2 end bits were 50mm wide.
Too nice to scrap or just cut up, it stood there waiting for inspiration.
They wanted cell phone stands but it was too thin at 20mm.
While making the other trivets, inspiration struck! It already had feet (sides) which I cut down to 10mm high.
Then painted it with the white-smelly-skin-remover stuff to get most of the old varnish off.
Some 180grit on ROS cleaned it up nicely
Top being sanded.
Base sanded.
There is a join, white section, that I was not sure how strong it was and certainly did not want it failing with a heavy Pyrex full of food on it.
I had some 8mm thick Pine strips12mm wide which would be ideal glued & screwed.
The strips fitted just below the feet which is great. Used 19mm screws.
The top would be routed similar to the other trivets, 7 round grooves evenly spaced. The one side was marked where the gloves went.
Grooved on the router table, adjusting the fence and then the top edges rounded over.
4 Coats of Woodoc 10 Interior with the final coat wiped off with kitchen towel to give a matt finish.
Base complete
One side
The other side
And the top
The Kiaat, like Imbuia, needs regular sniffing, so I would lift the router table top to get the smell!
