Windows
I’m dry fitting together a window frame (2x2s with mitred bridle joints). Individually the sides appear to be straight and square. Once assembled, the frame as a whole has some twist (3 corners touching the bench leaves the 4th corner 4-5mm off the bench). Assuming the individual sides are square and straight, I think this means that inaccuracies in my hand cut joints are angling the sides to produce the problem. How would you go about troubleshooting this to identify which corners are contributing to the problem? I think it has to be primarily the two corners next to the corner that is off the bench, doesn’t it? All tips welcome.
