A friend has moved house and is setting up his new workshop in a detached garage. I've offered to help fitting some repurposed kitchen cabinets onto the walls. I'm pretty sure the walls are brick, with no cavity, and I think are probably a single skin, ie half a brick thick.
What's a good way to make sure the contents of the cupboards don't rust?
If the walls are sometimes damper than a dry room in a house, so there's a risk of damp through the cabinet backs, would it help to put sheets of rigid foam insulation behind them? Would vertical battens make more sense?
Or what else should he/we do?
