What is it?
Something to nudge the grey cells...
the very first of its type but what is it?
Neither but thanks for having a go :D
Perhaps I should say 'What are they'?
The left one is for the Mk 9 left hand back door handle of the space schuttle and the right hand one is the Bristolian lever holding the door in place.
:lol:
Andyp":2eni9j4e said:
Do they need to be rotated 90 degrees anticlockwise?
Yes they do. They have been developed over the years. These are the originals. About 100 years old.
Pinch":2si4pc8e said:
A car jack?
:obscene-drinkingcheers:
No.
The two items would not work without each other ...well, they could but the end result would be disastrous. In their modern form they are in use around the world all the time. :eusa-think:
Rod":1obbx66p said:
WC parts?
10/10 for lateral thinking but no cigar, I'm afraid.
To give you some idea of scale, a man would lie comfortably in the u-shaped bracket if he wanted to.
Are they used by coffin makers?
It is not the cough that carries you off but the coffin they carry you off in. :D
LOL!
No, although what they were attached to in the early days could (and often did) become widow-makers. Still do sometimes these days due to operator error.
Sharp -no.
Form of transport - yes
Sled or carriage - no
Sent from my GT-I9195 using Tapatalk
TrimTheKing":2cpi5eh3 said:
Is the uppermost one a handle/crank of sorts and significantly smaller than the bottom one?
More a lever and sizewise probably about the same.
Andyp":moct7o2x said:
Does one of them turn something over?
Mmmm...not quite turn over (luckily for the original designer!)
So both around 6'-8' long then?
No, the u-shape thing, for example, is roughly the width of a man...not height!
If it helps, the items in my picture are American. The French developed a different item, with the same functionality, and which evolved to most of the ones in use today. I've used the French version.
Andyp":wvw5l1t6 said:
How long ago?
Last time I used a French version (which has been adopted worldwide) was back in 1999 although I did have a play with one last year in London :)
