I bet a simple oil change involves removing parts to get at the filtre.This is the Ford engine that will likely be powering the next car I buy. I can’t even find the spark plugs. There are 3 of them in there somewhere
somewherView attachment 37208
Thanks Mike, it is an ecoboost, 3 cylinder, 1 litre turbo, 125 bhp (ch here).My Ford truck has the 3.2L 5-cylinder diesel engine and my wife's Ford Mustang has the 2.3L 4-cylinder EcoBoost engine. I no longer bother with doing any of the maintenance myself.
Andy, if the motor is the 1.5L EcoBoost, you should do some research on it before buying. My neighbor bought a 2025 Ford Focus with this engine, and the car was at the dealer more than it was in his garage for various recurring engine issues. I didn't bother to ask what the issues were, but eventually, the dealer took the car back and he bought a BMW.
They use coil on plugs, remove the coils and down a deep hole you find the spark plug.I can’t even find the spark plugs. There are 3 of them in there somewhere
Love it!By contrast the old Morris 1000 I was clattering around in had an engine bay that you could almost climb into and stroll around.
Reminds me of the airline acronyms.....
Back in day FORD was an acronym for either Found On Road, Dead, or Ffing Old Rubbish from Dagenham. I think they have improved a lot since then.
Good. The other problem is, the oil pump drive was also a wet belt, so it may be worth checking they altered that, too.From what I have read the wet belt system has been replaced by chain now on the ecoboost engines for a few years now.
Edit… since 2018
We used to say "Fix Or Repair Daily" and they have improved in some areas but they look better now because many others have dropped down the league table to there level. The problems were annoying but not costly and could be fixed easily, now you get very costly and often only fixed by specialised garges and main dealers.Back in day FORD was an acronym for either Found On Road, Dead, or Ffing Old Rubbish from Dagenham. I think they have improved a lot since then.
Can recommend a VW Touran, we have a Diesel and it’s a good reliable workhorse, it’s the second one we’ve had,the first was rolled 5 times by my wife, all the airbags went off every panel crumpled, a builders bag of bits collected from across the slope she went down BUT she climbed out the passenger window with barely a bruise. Typical Pam she asked the people who stopped to help if they could help to put it back on its wheels so she could drive away. Paramedic persuaded her to get a hotel room.I had an epiphany last night. For weeks I have been looking for a car that we can fit a few objects in the boot as we do now.
A folding wheelchair for example is not easy for the missus to lay down and place in a conventional boot. Holding the weight while moving it forward requires some strength. Much easier if it is folded but remains upright. Now if said wheelchair is folded and laid on its back rather than upright it is just as easy to move but is 10cms less tall.
Daughter also rides ponies and needs a specific saddle rather than the ones available at the pony club. Trolley I made some time back to transport the saddle and other tack is tall but I have thought of a way to redesign it.
All this means we can look again at what the missus wanted in the first place. A more normal and refined car rather than a converted van.
VW Touran, which we viewed and dismissed, is now back in range. More conventional engine too.
Just avoid the 4x4 as they can be a nightmare when they go wrong. EGR on 2WD is straightforward but on the 4x4 it is a time consuming job with complications that result in big bills.but if you can find a low mileage model, a Skoda Yeti might suit. It has an OK boot,
1.6 or 2.0 TDI are good.I had an epiphany last night. For weeks I have been looking for a car that we can fit a few objects in the boot as we do now.
Mine's a very late 2018 Focus, it has a timing chain, but still a wet belt for the oil pump. I suppose you get a few more seconds before catastrophe.Good. The other problem is, the oil pump drive was also a wet belt, so it may be worth checking they altered that, too.
I would get that changed, which I think would require removing the timing chain. At the very least, I’d be dropping the sump to inspect and clean the oil pump pick-up strainer.Mine's a very late 2018 Focus, it has a timing chain, but still a wet belt for the oil pump. I suppose you get a few more seconds before catastrophe.
