Some time ago back before our new extension was built I made a couple of built in units to fill wall recesses near the patio doors to the conservatory.
The sketchup drawing I made it from-
and the finished item -
This proved a useful cupboard so it has stayed in use and is positioned in roughly the same place but the room has changed completely and there is no longer a recess for it and the wall has got a bit thicker too.
So project 1 is to make this cupboard with ugly sides that were never seen look good as a free standing unit. It also has to look like previously made furniture.
In particular the sideboard -
and dining table -
Next to the modified unit we need a cupboard for the cable box, media computer and AV amplifier so that is the second project. Again the style is similar.
Here is my incomplete sketchup with the side cladding for the tall unit, the new build AV cabinet and the final project a replacement coffee table that I'm still drawing.
I'm not in any great hurry with this but I have bought some White Oak (£130 worth) and made a start on the bits that don't need too much thinking about.
First bit of sawing
Unused 1" boards - they are about 230mm wide
And the 1 1/2" thick board for edging the tops
Then I resawed most of the pieces on the bandsaw
And ended up with a lot of curved wood after the cut released stresses in the planks.
So most of it was thicknessed to size as it is not flat enough to plane easily
Curve in the long strips
All these thin bits are sides of the 'legs' - box legs for the table and AV cabinet and fake box like corners for the tall unit.
Hopefully the way this all goes together the curve in the strips shouldn't be a problem.
To be continued..
and dining table -
First bit of sawing
To be continued..
