wizer
I would have avoided 'wool' type insulation due to sagging. But assume the Batts don't have that problem. :eusa-think:
RogerS":1ommcipz said:Always knew you were a bit batty, Malc ! :lol: :eusa-whistle:
wizer":cs5la3r0 said:Also, am I bonkers to consider doing away with the bricks and just building directly on the slab?
wizer":3olvlstt said:Thanks guys. Makes sense. Measured the OSB and it's 1200
I'm laid up with my back this week (first time in a few years, so can't complain). So I'm trying to focus on getting everything ready, design wise, to start framing in a couple of weeks.
I'm very much torn on the dwarf wall idea. Part of me wants to learn brick laying, but part of me feels it's holding me back from starting.
Being that I'm going for 5x2 timber now ( have ended up paying less than 4x2's), will bedding the sole plate on standard house bricks be an issue? i.e the sole plate will be wider than the bricks.
will1983":n69cupma said:You could do like Frank Howarth
wizer":2dkzst6x said:.....
I think I prefer the idea of it being surface mount. .....
paulrees1":11lg4ojc said:Wizer just a thought from my brick laying for a dwarf wall greenhouse. A cenent mixer can mix a LOT of cement, which puts the pressure on, and is a bit painful to clean up at the end of your session.
So my solution (tip from a bricklayer) was one of those big buckets end a paddle mixer from screwfix. You can mix enough for about ten bricks which would take me an hour to lay at the start, and it's a doddle to clear up.
Paul
Sent from my SM-G903F using Tapatalk
paulrees1":1veomvv5 said:..... and is a bit painful to clean up at the end of your session.
