Woodie chipbreaker
Salisbury, UK
My current refurb project of an old try plane is making progress but I've discovered that the chipbreaker will need a considerable amount of work to bring it up to snuff:
It's well out of square at both ends, but more worryingly, the threaded bolt is now very loose in the brass insert. I could fix the actual chipbreaker itself but the bolt/thread combo is beyond my measly metal bashing capabilities. Does anyone have a 2.5" (64mm) wide woodie chipbraker which is surplus to requirements? TIA - Rob
Edit - problem fixed, no need for a replacement
How did you fix it Rob?
I thought I had one but the widest I have is 2 1/4"
I had a delve into my taps tin and found I had an M10 tap so I drilled out (8.4mm drill) the old smaller thread in the cap iron (MikeG) and made a larger M10 metric thread. I also found in my bolts box a round head M10 Allen bolt so the whole thing is now much firmer:
One side of the cap iron (MikeG😁) was also about 2-3mm wider than the cutter (arrowed) and both ends were a long way off square, so 20 minutes work with a large bastard file brought everything tickety boo. Still a bit of shaping to do at the blade end followed by some final cleaning up with emery cloth etc - Rob
Are you using the iron + cap iron that came with it or your alternative one?
........Should be plane sailing form now on.
Well, that would certainly be an unusual thing to do, and I'm wondering where the mast would go. The obvious spot is taken up with bits of steel.
The iron is a replacement that I had lurking at the bottom of tool box somewhere and the cap iron is the original that I spent some time on yesterday - Rob
