A couple things i sometimes struggle with in regards to measuring, and best practices.
1. When you want to setup a combi square to a specific line on the rule, how do you do this when you can’t really “see” the line. Like for example in the pic below, its hard to tell if i am seeing the line or the reflection of the line in the stock, then the stock gets in the way. How do you do this accurately?
2. When setting a wheel marking gauge using a square blade, how do you set it when its hard to see? I suppose its not good to let the wheel fall into the groove? I sometimes have to hold it up to the light just right with some backlighting to see when the edge if the wheel is right on the line. Its clear in the pic I take as the iphone camera focuses in and adjusts light and is held close but my eyes from arms length its nowhere near this clear to see.
