Chisel cabinet
Doug
@dougsworkshop
I made this this wall cabinet just over a year ago to hold all the belts & bits for the Pro Edge plus centres, callipers etc for the lathe, it’s really been useful
So I figured it would be a good idea to make another one for my turning tools. Not liking to throw away any timber I had some used pine door frames which were not just ideal but also nice & dry
After planing up I made up some simple frames
Before gluing up I ran a rebate & fitted some Oak veneered MDF panels, once assembled they were cleaned up.
The doors were attached with piano hinges, pine pieces fitted to form a well & magnetic strips stuck to the panels which were clad each side with pine.
I then glued some maple veneer to the pine also sticking the veneer to the magnets with double sided tape & set in clamps
After a good sanding & wax polishing the cabinet was hung on the wall
Couple of photos of the finished cabinet
Welldone!
Sent from my iPad using Tapatalk Pro
That looks nice Doug. What holds it shut, and is there some sort of finger-grip or something to open it with?
On the top rail of both cabinets there are rare earth countersunk magnets these
https://www.first4magnets.com/circular- ... 1|ps_2-675
I just drill a shallow 10mm hole in the top rail & screw them in, there is a corresponding screw on the door this is enough to keep them shut.
I’ve not bothered with an opening mechanism, I was going to put a small knob on the bottom but I’ve found the doors are so easy to open with a little finger pressure on the underside of the door it’s not been necessary
I'm going to be the troublemaker!
I like its clean looks without handles.
Maybe a small indentation under each door to give fingertips something to pull against.
Not a troublemaker at all Malc it’s all personal choice, from a practical point of view I don’t like knobs or handles on workshop cabinets like this as I know the law of sod dictates that the next time I’m turning a long board round etc I will end up catching it also as this cabinet is behind the lathe the least sticking out the better.
Now that's a nice job. I've got my turning tools just stuck to an Ax magnetic bar but it's getting a trifle short for all the stuff I've accumulated. Worth making one of they I reckons. If it works without handles, no need to fit them as it's a workshop cabinet - Rob
