Failure only happens when you stop trying. Tenacity wins.
NickM":1y8ft8l3 said:It looks great!
Andyp":2ajn2o00 said:NickM":2ajn2o00 said:It looks great!
Agreed.
Looking good;I wish I had the resolve to build a musical instrument. Maybe some day.Well, it's not perfect, but for my first attempt with a guitar, it's not bad, I suppose.
Tape off and using that little 101 block plane to level the pufling.
There are all sorts of little gaps here and there, but too small to open up and fill.
It's not finished. I've just used cabinet scrapers to level the bindings to the front, back and rims.
I think it will look pretty when it's finished, and you won't see the blemishes from the audience.![]()
Constructing the neck looks to be a labour of love or hate. Progress is good Malc. What part of the guitar construction / assembly have you found most difficult.
Sort of, Andy. It has a handle at one end and connects to your cordless drill at the other, with a sanding drum or bobbin, in between. The one I have can fit any of the bobbins on my Triton oscillating belt and bobbin sander. So I can use a number of different diameter bobbins with it. So you hold it with two hands and can 'steer' it along the work to be sanded. A bit like when you roll your pastry, but powered by a drill.“Rolling Pin Sander”??
Is this just a sanding drum by a different name?
It's similar to a Martin heel profile. About 19mm will come off the bottom of that heel blank.Looks like a very shallow D profile Malc. Presumably this is per the plan?
Edit: obvs not seen the profile but the thickness suggests it.
Sorry Malc, I was talking about along the length of the neck.It's similar to a Martin heel profile. About 19mm will come off the bottom of that heel blank.
Sorry, I misunderstood. Plus the thickness of the fretboard.Sorry Malc, I was talking about along the length of the neck.
The forum software doesn’t load the code to show images as a gallery into the preview mode… it assumes that in preview you know your images and can see they are the right images in the right place without enlarging them…Admins, as suggested, I inserted images as thumbnails. However, when clicking on them in preview mode, they open in a new tab in my browser. this doesn't seem to have happened to me before. Have I done something wrong?
2 and a bit mm.Lengthy job but absolutely the right decision for a proper job. What fret width are you using?
