spearos
Slope your wall plates on the long walls.
EPDM is a simple DIY job.
Love it! :text-bravo:
timothyedoran":190fcp3s said:Here is a link to span tables.
9fingers":3o388dgc said:Should be fine. you need to build out a drip rail edge for the EPDM so the water lands near the centre of the guttering on the low edge and an upstand on the other edges so the water drains away.
9fingers":3o388dgc said:PS I assume you are ok on joist hangers now and my original scheme is no longer needed as your are draining from front to back now>
TrimTheKing":a6sf5iri said:No relation to your build Mark, and I know it's been said before, but that picture of your little girl in your avatar is an absolute belter! :eusa-clap:
Love that toddler enthusiasm and copying of what you do. Used to love seeing my kids pick up whatever I put down and copy whatever it was I had been doing, just beautiful.bscene-drinkingcheers:
9fingers":vlbro731 said:....Section through the garage 4.5 m internal width........
Mike G":16wa7set said:9fingers":16wa7set said:....Section through the garage 4.5 m internal width........
There's nothing wrong with that detail, Bob, but why add the complication? It appears to me the only gain is the reduced fascia size, but that comes at the expense (in effort terms) of two cuts at each joist end, and the minor expense of joist hangers. The simpler detail is just to sit the joists on top of the plates. Am I missing something?
Mike G":1769vmms said:However, just watch your block sizes. 140mm is standard, not 150, although 150 is available. Also timber is now 95 x 45.
Mike G":1769vmms said:Your biggest problem is that there is no reference face between the blocks and the timber frame, so you be guessing at dimensions a bit.
Mike G":1769vmms said:18mm OSB? Why? Half that thickness is more than enough.
jamieD":gx6xxl8z said:Hi Mark, sorry to but in...
spearos":cretx70u said:.....Just one question though - in your opinion, what should the minimum ventilation gap under the bottom FE board be?
Mike G":1p3a7qew said:Something in the range 10 to 25mm. Work out the gap to suit your insect mesh detail (and don't have any horizontal battens down there).
spearos":31af8wuw said:........On a side note, have you ever thought about writing a book on how to build a 'shed' properly? I think it would be rather popular!
spearos":1zi03ege said:Many thanks for the thorough explanation Bobbscene-drinkingcheers: Nice drawings there - what software/platform did you do them on if you don't mind me asking?
jamieD":2z7idotx said:I can see your getting some fantastic advice from the forum which is priceless!
Morning Timtimothyedoran":2t88fg8a said:Here is a link to span tables. These show the max span for a given timber and weight.
https://www.google.co.uk/url?sa=t&s...poKTGRQj10Db_RkAg&sig2=3ovgLVPR9-BsdjW4-vdzKA
Mike G":1lpwl6hb said:The old 4x2 regularised has almost gone with the dodo, in my experience. These days, most merchants stock CLS timber, which is machined to higher levels and has the corners rounded (ie arrises removed). It is ex-100x50, and actually measures 95x45. The threat of splinters is much reduced. It is dimensionally much more accurate than regularised timber ever was. I am pretty sure that it is only available "treated", but just check with your merchant nonetheless.
Feather edge board is much cheaper than shiplap. Shiplap provides a flatter finished appearance, but is thinner and less robust than feather edge. I always use ex 175x32 feather-edge..........or at least, I thought I did. It turns out it measures 180/ 185 in width. I am boarding my shed at the moment, and measured a piece yesterday. The thinner stuff (ex 25mm) curls and splits too readily in my view.
spearos":2dy3oztp said:I've been sifting through all the information the wonderful wide web offers
Malc2098":1rbxx8mn said:I have to say that I didn't go into much further than outer dimensions for mine.
The first time the triage office sent it back for: -
01. The floor plan and elevations submitted are not to a recognisable metric scale. Please re-submit at either 1:50, 1:100 or 1:200 scale.
02. Please submit separate drawings for each of the four elevations as we are unable to accept '3D' plans. Please also ensure that any doors and windows are shown.
03. The shape of the workshop on the Site Location and Block Plans does not match the floor plan. They should include the roofed decking area.
I had sent the Front, End Elevations and Plan on one sheet. I had a bit of a problem getting a recognisable scale interpreted from a 2D Sketchup drawing, but I got there in the end.
And after a phone call to explain that this was a garden workshop, not anything residential, it was accepted, as was.
