Woodbloke":q25t4qbt said:I was commenting very much 'tongue in cheek' Mike :lol:
So was I
Andyp":wj32hhjz said:Mike you will be able to video this wont you?
Mike G":12s8ra5a said:[youtube]4GstLDTR2jA[/youtube]
It works, as you can see. :eusa-dance: :eusa-dance: However, I'm not completely confident enough to mount the TV on it. I want to sort the cable runs out, the motor mounting, and fit an over-run kill switch before I fit it in the cabinet.
Cabinetman":zv5utr5m said:...... Mike I use a lot of nylon bushes/tubes 25 mil long 10 mm outside diameter takes a six mil bolt as an axle, I have 1 million, well quite a few, PM me if you would like me to pop some in the post to you. Ian
AndyT":oyyjs47g said:..........No chance of sneaking down in the night to watch something on the quiet though!
AJB Temple":21q1rzzb said:Very relieved that it works. :eusa-clap:
You could make another one wired to a burglar alarm and make a skeleton bearing a gun pop up.
I showed it to my friend. She's female (hence the she) and Irish. She said, it's all very well, but what if he has a power cut? He won't be able to get it up. :lol:
You can never be entirely sure when she's joking and whether double meanings are intended. So I just keep quiet.
She also remarked that soft start and finish would be nice. I said that is the normal state of affairs, but Mike likes to finish with a jolt.
Cncpaul":fipkc6lw said:Great job Mike, l bet you enjoyed building the lifter
AJB Temple":37q8ioy6 said:Very relieved that it works. :eusa-clap:
Rod":3lu9co39 said:Perhaps you could project a man playing an organ as it rises and falls like in the olden days [emoji3]
Mike G":wdwvr6yp said:A roof tent? I held a patent for a rooftent for a while. You can see the prototype I made on the Youtube channel were I've posted the TV lifter video. And I drove the length of Africa in the 90s using a homemade 4 man rooftent every night.
As for the linear actuator......well, the thing is I know there are loads of better ways of doing this thing. I mean, fabricating it from steel would be a start. But I've set out my stall now, and the damned thing is going to work.
