The Shetack Saw
AndyT
Bristol
Way back over a century ago in 1924, one Edward Oakley had a bright idea. Corrugated iron sheeting was a popular material for all sorts of roofing requirements, but it was difficult to cut. As far as I can tell, the standard tool was a cold chisel with a long curved edge, like this: (picture from a 1925 Melhuish catalogue)
but it must have taken ages. The portable angle grinder was still decades away in the future, and you couldn't even use a hacksaw, as the thin blade had to be held taut in a frame, and the frame got in the way if you were trying to cut something more than a few inches across.
But Edward must have been a clever chap as he developed his idea and took out patent GB 236448A, issued in 1925. Here are the drawings from it:
You can see that a normal hacksaw blade is held against a thin sheet of metal - rather like an ordinary backsaw - and tensioned by a threaded anchor. If you make your cut in the direction of the arrow marked in Fig.1 as 3-> there's a clear run at the blade, for as long as you want, like this:
Now, when I was at school, some of the time allocated to our brief lessons in woodwork and metalwork was given over to technical drawing and theory. (Presumably all 32 of us fighting over the sharp tools was too much even for our very patient teachers.) And some of the theory was copying out pictures and notes of tools, one of which was an odd-looking "Shetack Saw". Did this plant a seed that only germinated many years later? Maybe, but the name and the image lay dormant in my brain ever since.
So it was with great pleasure a little while back, when my good friend Andy B generously gave me this attractive and - to me - valuable! specimen from his collection...
You can see that the unusual surface treatment extended across most of the functional details, but it was indeed, a "Shetack" saw and matched my distant memories!
Before I embarked on putting it back into working order, I had a bit of a look into its history. These saws were made by Monument Tools.
Monument Tools is an unusual company. It was started, as Colliers of Brixton, back in 1880 and continued through five generations as a family firm. It still makes a wide range of very good tools, mostly for the plumbing trade, and manufactures them in Hackbridge, in the south-west London borough of Sutton.
They are rightly proud of their heritage and in the "Our History" section of their website, there's a clear statement: "In 1924, Arthur Collier Snr. buys the patent to the Shetack Saw from the inventor."
(There's also a longer history of them in the TATHS Journal number 7 here:
https://www.taths.org.uk/component/...ths-journals&id=154:journal-7-1992&Itemid=101
and a series of videos on their YouTube channel.)
The design has gone through several versions, which is easily seen by doing an image search or looking on auction sites. There's a good clear picture of the one that Arthur Collier donated to the Science Museum here
And so to the rust!
Following the recent discussions about electrolysis, and a substack linked to by @SteveMP , I thought I'd try that method. I'd done some before, but couldn't remember much about it. The article Steve referred to recommended using some proper steel for anodes, so I took the time to cut bits off a long steel bar that I bought donkey's years ago from a scrapyard. (I even used an electric angle grinder to cut it, which was a bit unusual for me, but I know it's somewhat harder than ordinary mild steel. The cutting disc made an impressive display of orange sparks, which I think is a good sign.)
I couldn't get a very good picture of the setup because of reflections from the bright sunshine, but here's one from part way through when I was changing the scummy water. The plastic bits are just to stop the saw from flopping over.
Also, I had a bit of an interruption to the process. It kicked off nicely with plenty of bubbling (next to an open window in a good draught) but then stopped. I could still hear a buzz from the transformer but when I checked the voltage it had gone down to less than half a volt. Fortunately, the fault was at the level of electronics I feel comfortable with - a soldered connection to the rectifier had parted company:
but was easily fixed.
The electrolysis did seem to have shifted the rust but had left a thick layer of soft blackness over the saw.
I gave it a few hours more and decided it was time to rinse everything off and start cleaning up by hand.
The good thing was that the rusted-up threads were now freed, revealing the tensioning bracket (which was at the other end in the original patent drawing).
I didn't take pictures of all of this stage, but you can probably imagine a wire brush or two, which did most of the work, plus a couple of abrasive blocks. I finished off with some fine wire wool and some microcrystalline wax, which should prevent any future rusting.
I found some text that had been hidden. On the hacksaw blade, the memorable old brand name, Ding-Dong, established 1899:
(Ad image from Grace's Guide)
I could also see that this saw was presumably an early example, not yet marked with the patent number, just the usual PATENT APPLIED FOR
but also this much rarer wording. Looking at it when it first showed up, I thought it said MADE IN BRIXTON but here on a big screen it looks more like MAKER on one line with BRIXTON below. Frustratingly, the first line is lost to time, but I expect it would have said COLLIER.
So there you have it, a little bit of British manufacturing history, a bit of an old geezer's reminiscing, and an example of how to get rid of lots of rust.
Thanks again to Andy @toolsntat for making it possible!
"DING-DONG!" Very cool tool and piece of history! Turned out a lovely patina on the metal. Interesting as I will need to be cutting some corrugated roof for an outdoor patio. Its funny, here in the states, a Ding-Dong is miniature cream filled chocolate "cake" dipped in chocolate.
Well that's all entirely new to me. I've never heard of a Shetack saw, nor Ding Dong saw blades, and nor have I ever seen anything like the configuration. Fascinating, and thanks for taking the trouble to do the research and post it here.
This reminded me of my saw, inherited from my grandfather. I'm pretty sure the handle is made by him, I believe during WW2 when he was an aircraft technician for the RAF. It's made from metal angle and cold riveted, consistent with materials and techniques for aircraft repair. The triangular shape would help cutting out damage in aircraft skins before riveting a patch.
The blades are off the shelf, and have some remnants of logos. Does anyone recognise them?
Interesting. I don't recognise those blades, sorry. There used to be "nests of saws" with three or more different blades that would fit on a single handle, but they used a slot at the end.
However, I found a listing on eBay that showed this saw, which is tapered like yours and does look like it has the same series of four bolts to hold the top edge:
Possibly more elegant, but I guess whoever made that one had access to bought blades like your grandfather did, but no ready source of aircraft rivets!
I can see how it would work well on thin sheet material. But there's no logo on this one.
Logo on pic 2 looks similar to old Disston logos, namely their Keystone saw logo which the produced for other manufacturers. Thats only based what I can see of the logo though
Thanks Andy & Steve, intersting info. I'm not convinced on the logo, the Disston corners look similar, but the rest is 'portrait' in aspect ratio, so I don't think it would fit the available space.
I'd guess that multiple places were producing blades, as the hacksaw blade has a red logo, and the wood blade is green and quite different in shape... as far as I can tell based on what little is left.
Edit -----
A google for Enox sheet saw produces a good photo of a NOS blade with the red logo. Green still a mystery!
Red and green for working on the port or starboard side of the aircraft. :ROFLMAO:
I have a Shetack basin (i.e. for the taps) wrench somewhere.
I don't think I've used it since the late 1970s, when I was a teenager, as modern 'monobloc' taps and modern, adjustable tools have rendered it pretty useless. And it's too lumpy to fit neatly into a toolbox. But Googling, I see they're still available, so someone evidently loves them still.
Your Shetack saw seems an altogether more useful proposition. Whilst it would take a while, and need a bit of effort, I can see it ought to work really well on corrugated "iron".
