I've been away from the workshop for a while, which is why there's been no visible progress, but I'm back now so here's a little update.
Having had something like success with the head end outer frame, it was relatively easy to repeat the same process at the foot end. I didn't photograph all the intermediate steps but the end result looks like this:
Obviously, there's some work still to be done - the tops need trimming off flush with the upper rail and there's half an inch to take off the feet before tapering them. Also, the joints are a little bit tight - which is why they are not all pulled up close. I can make up some long clamps for the actual glue-up but I'm relying on a soft faced mallet for assembly / disassembly at the moment, so I think it makes sense to leave the spare wood in place until as late as possible, to avoid damage to what will be finished surfaces.
I think I said earlier that I haven't drawn out every last detail of the design before starting. In my defence at what might be thought foolish, I have sketched out the constructional details and a bed is a relatively simple piece. It's deciding on the exact sizes and proportions that I struggle with from a drawing. I want to see and handle pieces of wood to decide what looks right.
One thing to do is to decide on the number, size and spacing of the slats.
The next paragraph or two may not endear me to most woodworkers under about 60, but I am of an age where I mostly think in inches, not millimetres (with plenty of exceptions too tedious to digress into). It suits my old tools and reading of old books as well, so please bear with me.
The space between the legs is 52⅜ inches. That measurement suits the mattress and is now fixed. If you multiply out so the unit is an eighth of an inch, that's (52x8)+3 = 419 eighths. Looking at pictures of other beds on line, including Derek's, I thought 15-17 slats would look about right. My wife and I agreed that we didn't want to group them into sets or include a wider panel or any of the usual variations on a theme.
For my first trial size, I settled on slats each 1⅝" wide, or 13 eighths. 15 slats would need 16 spaces.
The total width of the slats is 15x13 = 195 eighths. Subtract this from the available space: 419-195 = 224.
Divide 224 by 16 and you get exactly 14, or 1¾".
How about that? My guesstimate gives me a nice easy pair of measurements at the first go!
Having double checked my arithmetic, I used a trimming of ash from earlier and made some dummy slats of the right width and arranged them at the chosen spacing, like this:
I think that looks ok, but do shout if you think a different way would be better.
I do also need to consider and decide about the thickness of these slats and whether the tenons are going to be shouldered or barefaced. Here's a view of the inside of my head at odd moments:
Shouldered - Pro:
- Hides any irregularities in the mortices
Fun to do?
Impresses other woodworkers
Allows for thicker slats which will share the sturdy look of the bed.
Shouldered - Con:
- All my spare ash to make the slats is thicker than I need for one but not thick enough for two, which means lots of sawing and planing
There's all that fiddly fitting to do
No way to hide a slat that's too short.
Bare-faced - Pro:
- No fiddly fitting of shoulders
I can cut two thin slats out of my thick offcuts
Slats don't need to fit accurately at both ends, making fitting and glue-up easier
Short lengths of ash are stiff and strong even if only half an inch thick.
Bare-faced - Con:
- Every slip would show. I'm not going to start using my powered router for this - I've never used it for mortises and would be inviting trouble.
Might look lightweight.
Your helpful thoughts are welcome but this isn't a democracy and your votes may be over-ruled!
I'll do some experiments before I decide for definite.
And if that's not enough, there's another aesthetic question I need to decide on - tapering the legs.
Derek's appears to have a taper on the two inside faces which I think looks good, but how big should it be? I already have a dummy softwood fencepost leg I prepared earlier, so here it is getting a trial taper on the bandsaw. The slope starts an inch below the bottom edge of the rails and there's a reduction of half an inch at the foot of the leg.
Is that too much, or too little? What would Goldilocks do? :?
