DaveL
Which controller have you got?
Robert":1x7xplrd said:Malc2098":1x7xplrd said:The safety circuit I'm trying to achieve here, is to cut the power to the VFD and hence the spindle (230v), but leave power to the controller (24vDC), so that I can reset the job.
Can you explain that a bit more please.
How does stopping the spindle help anything? If the axes are still moving a stopped cutter will do nearly as much damage to the workpiece as a moving one. Don't you need an emergency pause button?
On the metal punching CNC that meant pressing the single step button. Then you'd have to press start for every line of gcode to progress and could sort out a bent edge or whatever at leisure. E stop was for when the sheet of metal got screwed up and the program abandoned.
Robert":33io08q3 said:Stupid question - you have a stop button - is there a physical cycle start button...single step button etc that I remember or is it all software initiated - click go on a PC screen or similar?
novocaine":blez7xhf said:check in the controller manual before you go to much further on the spindle stop Malcolm. A lot of modern controllers have a restart after power loss. unlike the good old days, the code is stored in eeprom rather than RAM, so it remembers it's last known position. It also normally starts back up in manual override to so you can jog through the code and check it's position before it starts again. I swear that black magic is at work to do this. :lol:
Robert":3b5jllnw said:I watched a couple of youtube videos of people building this brand CNC this morning. Not the full build just partial. Reviews were generally pretty good. One commented the mechanical parts had good accuracy. Also said the mechanical instructions were very good and the electrical ones not so clear to follow.
Keep posting![]()
9fingers":1adarqji said:Malc,
I'm sure somewhere there will be an enthusiasts forum for this machine and just like here, there will people who tend to be helpful and their names will keep popping up and equally there will be sources of random noise.
I tend to lurk for a while and work out the helpful guys and how to drive the search function.
Research your queries and then post questions to clarify your uncertainties and see what the helpful guys say.
Watching with great interest.
Robert":xxe4oxyn said:Does the manual give a total weight for the machine? Couldn't see any mention of weight on Ali ex.
Obviously would have to add the weight of the MDF panel.
Malc2098":3dkssz1h said:It's getting frightening! I might have to switch on tomorrow!![]()
RogerS":1t5lezcz said:Silly question but there isn't a mechanical lock/carriage protection gizmo inside the motors that has to be removed?
RogerS":1ikww83s said:OK...worth a try. I know little about these motors but wondering if perhaps you had a couple of windings that were accidentally wired to oppose each other....might account for the sound you hear.
Malc2098":oly3lxjj said:I've flashed my firmware!!![]()
(Used to nick people for that in the 70s!!)
