nice one Malc
9fingers":3l576677 said:The z error could be caused by missing steps or a bit of unwanted flexing of the gantry
I presume there is negligible end float in the spindle itself.
Robert":3r1d4hxq said:Well done
Next challenge to make something you designed and coded from scratch? Even if it is just a rectangle.
Phil":1c2tyt0x said:Malc, looks good seeing it working. Impressive stuff![]()
Like Robert I was perplexed by your post but had over looked the two feed screws give scope for error. All clear now. Tramming my mill is a job I hate and go out of my to avoid tasks that need it to be used at an angle and then need to be reset.Malc2098":wjh625kq said:Thanks, Gents.
I'm not sure, Robert. I only turned one of the Y screws while the steppers were un-energised, so I believe the other Y (A) screw stayed where it was. I also moved the limit switch by the same amount and re-homed after each go at the triangle and the Y screw went to the limit switch. There isn't a limit switch on the other Y (A) screw.
NickM":3gnka6v5 said:That’s very clever! Is the hoovering hand CNC controlled too?
novocaine":2l7y12n0 said:Yer, but whi the beeeb is Alice?
(Not a chubby brown fan, it is the only thing I think I've ever seen of his)
9fingers":23qg3xjn said:Malc. Having got the machine to this level of functionality were any of the problems caused by insufficient/inadequate information provided by the kit supplier or mainly due to your lack of know how, errors in setting up?
I'm not knocking you in anyway but I'd have expected a kit supplier to have provided every last item of hardware/software/set up information etc that would be needed and that would be how they earn/justify their margin compared to buying the components individually.
Would any other kit supplier perhaps have been better with the benefit of hindsight?
Cncpaul":3ehm4kzj said:Would hinged from the wall be a better option ?
droogs":292fi9wd said:What about a tablesaw/router bed flip top stand on a slowmo motor connected to a PA that plays Thunderbirds each time you change use? That's what I'd do, honestly :lol:
If you can't be bothered then provided your rafters are big enough go with the pulleys
