MY63
Mike G":39eibv2v said:MY63":39eibv2v said:.......I bought what I thought was the correct straps for fixing the sole plate to the lintel but they are about 3mm......
Those are the normal heavy duty tie down straps for houses and so on. They'll be massively too long, and overkill for this little shed. My 30m sq workshop only has the thin universal banding on a roll, which is loads cheaper, and you can just snip it with tin snips, so that's what I suggest is used.
I believe that is what they are although they would fit they are 2 x 50 x 200 mm.
I am currently re reading the section on your post regarding DPC which I believe does require a mortar fillet to sit on. With a length of 100 x 50 mm sat on top to hold it down ?
