Clever and fascinating as always.
AJB Temple":1l5q7ssb said:As a matter of interest Malc, do uke's use different neck profiles? I guess the neck is short and there are only 4 strings, so not wide either, so maybe makes little difference. With electric guitars I've always struggled with LP profiles, and my favourite "work" guitar, custom shop strat, has a very slim almost triangular profile that is very fast.
Second question, do ukes tend to have a different bridge cross section to acoustic guitars? Pretty much every acoustic I have ever owned (mostly Taylor, Martin, SC and Gibson, but a few others) has had a spread and tapered bridge (the ebony bit not the bone part or parts). Uke's seem to use a more straightforward block like design with less spread across the top soundboard?
Woodbloke":21vxnycx said:Nice job on those: I do like a bit of Ebony- Rob
Malc2098":19nsrvog said:thetyreman":19nsrvog said:looks good! what is the fretboard taper on this? I ask because I want to make an electric one at some point in the future.
Thank you.
The taper is 36mm nut to 45mm end of fretboard, essentially 21st fret position.
thetyreman":1duyhyho said:Malc2098":1duyhyho said:thetyreman":1duyhyho said:looks good! what is the fretboard taper on this? I ask because I want to make an electric one at some point in the future.
Thank you.
appreciated! thankyou
RogerS":3vmns1jl said:This whole thread is fantastic :eusa-clap:
Many thanks, Malc, for all the quality work and showing us along the way.bscene-drinkingcheers:
thetyreman":1eej8x6o said:what glue will you use for the bracing?
AndyT":1lclc6d4 said:I've been rather quiet up to now, but I really must join add my voice to the chorus of appreciation. Even as a non-musician who will never attempt anything like this, I can see the huge amount of practical problem solving that goes into your builds. And the level of precision. And patience. Oh, and ingenuity as well.
Not to mention brilliantly clear photos and description. It's very impressive and much appreciated.
:eusa-clap: :eusa-clap: :eusa-clap:
Andyp":9ii8mrdf said:My favourite part of this process is that go bar clamping device. It looks so out of this worldly.
Robert":2l2iokz1 said:I've not had much to say on this thread but I'm enjoying following along the process.
Thanks Malc for the pictures and explanations. Fair amount of effort in presenting here never mind the making.
